Re: Super A won't start/run
Posted by Mark (PA) on June 09, 2007 at 13:29:24 from (207.255.75.181):
In Reply to: Re: Super A won't start/run posted by El Toro on June 09, 2007 at 13:23:06:
Hal
THe plugs are brand new. I just put them in this AM so they aren't it. Unless 3 of the 4 are bad! heh. I set the gap to .023 per the manual before putting them in. I think that is what you mean though just a misprint above. I will try the coil wire and see what it does. I'll report back here. Thanks so far!
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
