Re: Super A won't start/run
Posted by El Toro on June 09, 2007 at 13:23:06 from (152.163.100.197):
In Reply to: Re: Super A won't start/run posted by Mark (PA) on June 09, 2007 at 12:45:38:
I would install new plugs to see if they're the problem. You should pull the coil wire from the cap and hold it within 1/8-1/4" of a good ground on the tractor's frame. Then have somone crank the engine and see what the spark looks like. It should be hot and blue. If it is I would replace the cap and rotor. If the fire is weak from the coil wire I would replace the points if they're pitted. I would clean the old points until nice and shiny with some 320 wet or dry. I would replace the condenser to eleminate it. Make sure you check the point gap, it should be at .013". If this doesn't improve the power you may have a weak coil. Hal
PS: The plug wires may need replacing. You need wires with copper wire when using a mag.
