Re: UPDATE. PLEASE READ
Posted by El Toro on June 09, 2007 at 17:08:01 from (205.188.116.138):
In Reply to: UPDATE. PLEASE READ posted by Mark (PA) on June 09, 2007 at 13:51:21:
third party image
You probably have a distributor and you should have an auto type coil. Are you using a ballast resistor between the ignition switch and the coil?
Does your coil look similar to the one in this picture? Hal
PS: That coil wire may be your problem. I would replace it to rule it out.
