Re: Will an M operate a round-baler?
Posted by Grabatire on June 10, 2007 at 15:52:46 from (216.95.83.207):
In Reply to: Will an M operate a round-baler? posted by M.Rad. on June 10, 2007 at 15:39:50:
My '52 SM had no problem power-wise, even in fourth gear but it wasn't being used on hilly terrain. I had to renovate the hydraulics a bit to handle the tie and unload systems. Other than being slow and a and a bit rough to ride over the mole hills it worked OK. The biggest trick was learning to deal with the nonlive PTO handicap.
