Re: Will an M operate a round-baler?
Posted by Ronald on June 10, 2007 at 19:12:49 from (205.188.116.138):
In Reply to: Will an M operate a round-baler? posted by M.Rad. on June 10, 2007 at 15:39:50:
Look at a older smaller vermeer, like a 504c (MF 450 is the same thing). I ran one with an H once when I had nothing else to use. A M would handle it good on decent ground. They are definitly not the best baler in the world and not the easiest to use, but I think if I remember right require 35 hp. Most had rope tie, so you would only need one two way valve. Price wise you should be able to pick one up for 1500 or less.
