Re: Will an M operate a round-baler?
Posted by georgeky on June 10, 2007 at 19:44:14 from (205.188.116.138):
In Reply to: Will an M operate a round-baler? posted by M.Rad. on June 10, 2007 at 15:39:50:
If your M has live hydraulics it will handle several rollers. The lack of live PTO will be the biggest concern, but will work without it. Any small roller should be ok and lots of the older big balers such as IH241 or 2400 or JD 500,510 or smaller 410 and 430. I have pulled both IH models and a 510 JD with my 350 and it works fine, but it has IPTO and live hydraulics. I have a neighbor that pulls a 605 Vermeer with a Super MTA and rolls lots of hay with it. Rollers are like lots of other things that don't require as much power as lots of folks think.
