Re: '41 H Belt pully seal
Posted by Nebraska Kirk on June 11, 2007 at 19:13:46 from (207.91.30.31):
In Reply to: '41 H Belt pully seal posted by Hagwoodhunter on June 10, 2007 at 22:16:44:
Funderbunk is right. Once you get the shaft out, you have to remove the bevel gear and the two bearings and then you can remove the end housing that holds the seal.
