F-12 Power Lift and Peg for Seat Brackets
Posted by Dan Oehmke on June 11, 2007 at 20:17:59 from (71.48.121.2):
On an F-12 Power Lift, how do you remove the pin/peg that holds the seat bracket on? I need to get this off so can replace the stripped bolts that hold the seat brackets together. It looks like it should remove to the right side? And will it need some heat from a torch? Thanks, Dan
