Re: F-12 Power Lift and Peg for Seat Brackets
Posted by David Allgire on June 14, 2007 at 06:48:36 from (24.217.111.191):
In Reply to: F-12 Power Lift and Peg for Seat Brackets posted by Dan Oehmke on June 11, 2007 at 20:17:59:
Yeah it can be a pain. Pull both cotter pins. I used a long bar that will fit through the hole in the support to start the pin moving toward the left. Then I went to the left side and did the same. There is no hole on the left side so you have to strike the pin at an angle. I also applied some Kroil to loosen things up. By moving the pin back and forth, you break the rust bond and can get a pair of vise grips on the right end and finally twist it out. I didn't have to use any heat. Just got to be persistant! Hope this helps.
