Re: Farmall Cub Hydrolic Box
Posted by Michael Sheik on June 12, 2007 at 11:02:10 from (199.153.205.246):
In Reply to: Farmall Cub Hydrolic Box posted by Roger Kansas on June 12, 2007 at 09:13:48:
Just did the one on my dad's '51 Cub. That plate is really stuck on there good. Don't know if the factory used some sort of sealer on the gasket or whether is was all those years causing it to be bonded so well . I had to take a chisel with a sharp edge and wedge between the plate and housing, tapping it in a little ways in numerous locations and it finally came apart. Be careful and drive in the chisel where is does not cut into the metal on either side. Go slow!
