Re: Woods mower
Posted by Nawlens_Gator on June 13, 2007 at 13:40:20 from (52.128.30.25):
In Reply to: Woods mower posted by the Unforgiven on June 13, 2007 at 11:46:06:
Nat,
His PTO pulley needs to be 3 times the Cub's PTO pulley diameter, not the mower's pulley diameter (unless of course they are the same D).
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
