Re: Woods mower
Posted by billde on June 13, 2007 at 16:51:18 from (66.249.52.188):
In Reply to: Woods mower posted by the Unforgiven on June 13, 2007 at 11:46:06:
42" takes the same pulley for a Cub part no WB-1-74 73/4 in dia. You will need to go with the biggest pulley available for the PTO and go to a smaller driven pulley to get your speed. unless you get an extended hub you can only use a 10 in drive without hitting the fender.
Driven pulley on my 42 is 10 inches.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
