Flames out the exaust!!
Posted by jonnny2006 on June 13, 2007 at 20:58:38 from (67.142.130.31):
on my 44 H it has a miss on the number 2 piston. i can take the wire off at a idle and it dosent make a bit of diffrence... The wire and plug are bran new even took off a good running tractor. new cap also. took the plug out and ran it and it has hot spark every time the rotor gives it juice. but if i leave it off and rev up the engine fast it stutters v.s. if i leave it on the plug. plus under load it seams to be better. I have adjusted all the valves to .20 cold. or 17 warm. I am thinking it is an exaust valve not closing all the way due to a week valve spring. When i pulled the valve cover off i rember seeing a spring that looked shorter then the rest of them.... I thought it was just the position of the engine. but now i got to thinking i have never seen one that had one like that before. so im hoping thats it. As it puffs blue flame out the exaust every once and a while. I don't wanna scorch the valve so i better fix her. I don't work her hard no more as she is retired but i would like it to run right. the carb is adjusted correctly and the timimg is right on the money. I have even played with both just to see if i could make it go away. I bet the spring is weak and is not closing the valve all the way. any thoughts???? is the best way to change the valve spring to put some soft rope down the cylinder untill it pops the valve open so i can work on the valve? i know you can use air also but i think the rope idea should work.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
