Re: Flames out the exaust!!
Posted by K.B.-826 on June 13, 2007 at 21:27:53 from (66.188.208.110):
In Reply to: Flames out the exaust!! posted by jonnny2006 on June 13, 2007 at 20:58:38:
How about a compression test? If you do need to change out the valve spring, position the engine so that #2 is about mid stroke coming up on compression stroke, stuff as much rope as you can down the plug hole, then roll it up to the top of compression stroke. That way, your rope will be pushing hard against the valve preventing it from dropping. Nice thing about using compressed air is that you can also use it to leak test the cylinder. Position cylinder to be tested at TDC compression stroke. Have to be exactly at TDC or air will push the piston down. Apply compressed air and listen. If valves are leaking, you'll hear air flowing through the manifolds. If rings are leaking, you'll hear air as you listen through the oil fill opening. If it's a blown head gasket between two cylinders, you'll hear the air leaking into the cylinder next door. If you've got a bad head gasket leak to the cooling system, you'll get bubbles in the radiator.
Home
| Forums
Today's Featured Article -
The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
