Re: Farmall H drive shaft coupling removal
Posted by kfox on June 14, 2007 at 21:31:33 from (63.18.178.114):
In Reply to: Farmall H drive shaft coupling removal posted by SLH IN MO on June 14, 2007 at 16:29:26:
The first thing you will need is a good air mattress because you will be spending some time on your back. The second thing is a good trouble light with a guard on it so it won't burn a hole in your air cushion. (don't ask) :-) My Grandson got a new one out of the deal. The bolts in the coupling can be a real bear. Don't use a hammer on them. I don't think you need a sealed bearing because that bearing is well lubed from the transmission, and you still will need the new seal. ken
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
