Re: Anybody actually done it? Super C rear axle seal?
Posted by Ed342 on June 15, 2007 at 08:47:37 from (216.234.120.22):
In Reply to: Anybody actually done it? Super C rear axle seal? posted by leon on June 15, 2007 at 03:09:49:
Others with better experience may advise you differently and please defer to them. However I am in the process of changing out a right axle on a '53 Super C now and happy to share on that and hope it helps you with yours. So far we've removed the wheel, wheel weights and having some trouble getting the top (deck) off the gear box. This is a lot easier with 2 guys because of the weight but 1 guy can do it. A couple bolt heads broke off which can be replaced ok. One, left front corner is in a bad spot for tapping out and will add some time to the job. This same bolt is holding the deck and if it doesn't tap out I will have to fully remove the controls 'tree' which is another hours work but only a small pain. We were able to raise the deck up from the rear and I can see into the box. The big gear on the right is loose and just laying cocked in there. So my point is you may be able to come in through the pto but you may discover you need to get fully into the rear end box to examine and/or make other adjustments or replacements. So you might want to just take the bit in your teeth and go in from the top. By the way, instead of using standard WD-40 I took a recommendation from a kid working at a Home Depot and am using a spray can of PB Blaster. It's a world better than anything else I've seen, including WD by far. On an otherwise rust free tractor that has had a lot of obvious good care over the years I was surprised to find that the bolts that broke off had rusted 50% through close under their heads in the deck plate itself. One of the bigger problems I've found is can't seem to locate a diagram of where all the gears should be and what torques, adjustments, alignments, etc. should be. I've called the companies that sell the full manuals and so far, to my surprise, haven't found one that includes this in their manuals. Once I get fully into the box I'm going to want to make sure I get everything back together correctly and replace any and all parts that might need it. This is obviously not a job I'm wanting to do twice. Hope any of this helps. Ed342 - Northville, MI
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
