Re: super c leaking from axel
Posted by Dave BN on June 16, 2007 at 13:41:45 from (152.163.100.197):
In Reply to: super c leaking from axel posted by mike in va. on June 16, 2007 at 06:06:35:
This is a two part seal and you will need to pull the wheel off to change it. Make sure their are no sharp spots or burrs on the axle to cut the new seal as it slides on. I clean and oil the axle to help slide that seal on. By the way, their is an inner seal inside the transmission that is leaking also as the axle housing should not have oil in it. Most guys including myself just replace the outer seal that you have asked about and call it good. Breaking the wheel clamp bolts loose might be fun, mine were. Lots of penetrating oil and a big wrench with a cheater pipe got mine loose. Good luck. Dave.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
