Re: Wiring--a little confusion.
Posted by KEB on June 16, 2007 at 19:47:29 from (72.19.170.5):
In Reply to: Wiring--a little confusion. posted by Thomas D Windsor on June 16, 2007 at 17:58:35:
No, the ammeter does not go to ground. The ammeter indicates whether current is flowing into or out of the battery. The fact that its positive ground only changes the direction the ammeter indicates, not the path that the current follows.
One side of the ammeter should connect to the ungrounded battery terminal, in this case the negative terminal. The other side should connect to the battery terminal of the voltage regulator (or to the battery side of the cutout relay if that's what you have), and to all the various loads (lights & ignition).
Turn on the lights with the engine not running. The ammeter should show a discharge. If it indicates charge, simply swap the connections to the terminals on the back of the ammeter.
Keith
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
