Re: Use Grease If Necessary
Posted by georgeky on June 16, 2007 at 20:58:28 from (205.188.116.138):
In Reply to: Re: Use Grease If Necessary posted by Troy Lindsey on June 16, 2007 at 19:12:37:
Troy you don't need a machinest. The plug is a square headed plug. A long handled adjustable wrench should screw it right out. If the head is messed up a pipe wrench will work and new plugs are available at any good hardware or plumbing supply house.
