Re: Wiring--a little confusion.
Posted by John T on June 17, 2007 at 06:36:27 from (66.244.83.147):
In Reply to: Re: Wiring--a little confusion. posted by Thomas D Windsor on June 16, 2007 at 19:51:39:
On a Positive ground tractor the gennys output connects to the Negative battery post and the charging current patch is as I described above. To avoid confusion in Pos versus Neg grounded tractors, I refer to that battery post (where battery gets charged from genny) as the HOT UNGROUNDED POST.
A battery is the same and all works as the DC voltage is BETWEEN the 2 batery posts REGARDLESS which post you tie to a huge hunk of iron and use the iron as the return current path versus havin to run 2 wires to everything.
John T
