Super M will not shift into either first or reverse
Posted by Al57 on June 17, 2007 at 14:05:12 from (64.12.117.8):
The shift lever will not go far enough to the left to allow me to shift into either reverse or first gear. I can shift into the other gears.
Any suggestions on how to fix the problem will be appreciated.
Al
