Re: Super M will not shift into either first or reverse
Posted by Bob Kerr on June 17, 2007 at 19:30:45 from (205.188.116.138):
In Reply to: Super M will not shift into either first or reverse posted by Al57 on June 17, 2007 at 14:05:12:
If you can shift other gears, sounds like you might have a broken shift fork or the slider has acted up somehow. May be possible that some crud got down the shifter hole and is not letting the lever move over. The crud in my H was pretty stiff stuff, almost like old rubber, but it was dirt.
