Re: Wiring Question On Dash For 400
Posted by John T on June 17, 2007 at 19:23:28 from (66.244.83.147):
In Reply to: Wiring Question On Dash For 400 posted by Big Country on June 17, 2007 at 19:09:10:
There should be ONLY ONE WIRE on the SUPPLY terminal of the ammeter, thats the one wired to the starter switch (BAT input terminal NOT starter side) where the big battery cable is down from the hot ungrounded battery post...... The ammeters other LOAD terminal wires to the BAT terminal on a Voltage Regulator or the main output stud on an Alternator PLUSSSSSSS feeds hot battery voltage to all loads such as lights and ignition. Put the alternator or genny output on the LOAD terminal of the ammeter, the same terminal that is wired to the lights or ignition switches to supply them with hot voltage. If you turn the ignition or lights on tractor not running, the ammeter should swing to - discgharge and then once started if shes charging it will swing over to + charge. If it does the opposite, its wired backwards so simply reverse its leads. On a neg ground tractor the ignition coils lil - terminal is the one that wires to the distributor while on a Pos ground it would be its + terminal. John T
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
