Re: water pump 140?
Posted by baccerfarmer2 on June 17, 2007 at 19:37:08 from (166.165.242.66):
In Reply to: water pump 140? posted by baccerfarmer2 on June 17, 2007 at 14:09:41:
thanks, from the casting numbers you gave me it looks like I have a 100 block. I looked up a picture of a water pump for a 100 and it showed that it bolted on the lower right side of the engine. Would the hole in the head be different from a 100 than a 140? As for the bolt in I measured everything and seems to fit. could I possibly get a water pump for a 100 and make it work without changing the radiator, thermostat and all that other stuff?
