Re: water pump 140?
Posted by Stan(VA). on June 18, 2007 at 08:51:04 from (67.142.130.25):
In Reply to: Re: water pump 140? posted by baccerfarmer2 on June 17, 2007 at 19:37:08:
Hugh, thanks for posting the block numbers, didn't have time to look them up again yesterday. I think the 354898 R1 and R2 were both used in the Super's (my '54 Super C block was an R2) and seem to recall we found the 100/200 used the R3. That would be when they started casting the C-123 ID on the block, stopped using the old FCM or FAAM motor prefixes, switched to the C123 prefix and restarted the engine serial numbers at 501. Back to this thread: The bolt spacing on the front of the head is the same so you could use either water inlet/thermostat housing. Your problem is that if you stick with the 140 housing it will line up with your radiator neck but will need a bypass blocked off and have no way to mount a fan and belt pulley assy; the 100 housing won't line up with the radiator, but will allow you to mount the old style fan and pulley assy which will line up with the old style water pump. This would require the old style front pulley with the wider fan belt but be aware that the pulleys mount differently as well and you didn't mention if you are trying to use a 140 or 100 style crankshaft which would have the narrow or wide pulley respectively. I realize that the engine will bolt in; my comment about it not being a "bolt in swap" may have been more clear if I had said that the 140 and 100 blocks are not a direct interchange. I have done the opposite of what you are doing (put a 140 block into a Super C) and that exercise was the basis for the comments. Going the other way you may find some short cuts that weren't open to me? I even recall custom machining an old style pulley once to fit a newer crankshaft but that was a different project. Possible? Certainly. Simple as bolting on a different style water pump? No. Stan(VA).
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
