Re: Took some pics.....
Posted by D Slater on June 18, 2007 at 09:58:19 from (72.65.144.253):
In Reply to: Re: Took some pics..... posted by Patrick Martin on June 17, 2007 at 21:36:52:
Tractor is newer than a 39 or 40 model unless transmission top cover and PTO were changed. If engine kits contain crankshaft bearings that is one reason they want serial # of engine. Change was made to bigger crankshaft journals on late M. If a sleeve was cracked or split before you removed it there's a good chance block is cracked there also. On side of engine block oil filter side, look above oil filter and above tappet cover. Near rear should be a block casting # , 4 numbers followed by 2 letters. Going toward front of engine near same level look for cast date of block. (example .4.6.T. = april 6 1950) It may or may not have raised dots on each side of # or letter. On toward front of engine and very near front will be a flat on block just above tappet cover,the serial # with prefix and suffix if any should be stamped in. Some engine blocks were replaced and no serial # stamped. If you find date code of engine it will give a idea of the tractor year if engine is original. Most M tractor and engine serial # don't match. Radiators are changed a lot so this is not much to go on but your radiator is not a low pressure type used on early tractors.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
