Re: int'l 300 hydraulic pump
Posted by Bill46 on June 18, 2007 at 10:00:59 from (65.200.157.177):
In Reply to: int'l 300 hydraulic pump posted by r. Bond on June 18, 2007 at 09:24:44:
Did you run it dry? If so the pump is more than likely gone. If it would still measure on the stick...it may just have air in it.
Drain a small amount out of the resovior in a clean coffee can and see what you get. if there is junk in it...you may have cooked the pump. Insure its full and cycle it a few times...maybe just air.
Also, there is a screen in the hyd tank...but that is a booger to clean.
