Re: Pneumatic Lift-all on a Farmall A
Posted by gene bender on June 18, 2007 at 10:40:20 from (67.55.226.214):
In Reply to: Pneumatic Lift-all on a Farmall A posted by farmallbob on June 18, 2007 at 06:23:24:
I have and have sold several with the lift system when new but i will say the automatic system was used on the early models. With a mounted plow the automatic system would have been better as the pressure was off the the cycl when the plow was up and to trip the plow only required pulling the trip lever. This system would have been great for the B and BN187. Someday i am going to make that system work on mine.
