Re: No spark to plug (Farmall A)
Posted by Janicholson on June 18, 2007 at 16:25:04 from (66.173.50.17):
In Reply to: No spark to plug (Farmall A) posted by Randy McC on June 18, 2007 at 15:55:33:
The cap could have an internal short to ground.
The rotor needs to point to the tower terminal for #1 when the impulse coupling clicks (can be done on the bench with a marker to mark locations)
mag coil to mag cap high voltage wire could be open (broken inside).
Rotor could be shorted to rotor shaft cracked internally. These are where I would start. JimN
