Re: No spark to plug (Farmall A)
Posted by Paul Shuler on June 18, 2007 at 17:52:41 from (170.29.248.3):
In Reply to: No spark to plug (Farmall A) posted by Randy McC on June 18, 2007 at 15:55:33:
Are you sure it is timed to the engine? With #1 cyl up at TDC of the compression stroke. The rotor should be pointing right at the #1 terminal of the dist cap. If not, you can remove the two small screws that hold the little cover on where the shaft that turns the rotor comes out of the mag. There is two small gears in there and you can pull the little shaft out and rotate it to where it would be pointing the rotor at #1 and slide it back in then you are good to go. First be dead sure you are TDC on #1 on the compression stroke. You can determin this by pulling plug #1 one {closest to the radiator} and put your finger over the hole while someone taps the starter. You will feel a big rush of air as the piston comes up on comp. You then can pull the inspection plate on the bottom of the clutch housing and see if your timeing mark is lined up on the fly wheel. Sometimes the mark is very hard to see. Have a good light handy. Hope this helps Paul
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
