Re: No Oil Pressure on rebuild
Posted by Jim Allen on June 19, 2007 at 06:03:40 from (209.173.160.22):
In Reply to: No Oil Pressure on rebuild posted by Thomas D Windsor on June 18, 2007 at 20:09:33:
Using pertroleum jelly in oil pumps has long been accepted practice for oil pumps in rebuilds, especially for engines with high-mounted, external pumps or those that will sit a while before being started. In fact, I had factory tech training (in England) on Land Rovers in the '80s and that was the recommended stuff. We also used it as a general purpose seal lube, even in automatic transmissions. It's gooy enough to help the pump prime and provide initial lubrication. It doesn't run out if the engine sits for a while before starting but it melts/dissolved very quickly and does not contain any elements that will contaminate the primary lubricant. There are probably better assembly-lube products available these days, but there's certainly nuthin' wrong with petroleum jelly. As to the problem at hand, presumably you filled the oil filter with oil first? Anyway, if you used a good assembly lube on the bearings, cam and other moving parts, you're OK to start the engine, IMHO, and let it idle for 10 seconds or so to get the oil pressure up. At idle, you aren't doing any more damage than spinning it over excessively with the starter. As stated, a pre-luber is the best idea if you can get your hands on one. Jim
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
