Re: No Oil Pressure on rebuild
Posted by the Unforgiven on June 19, 2007 at 10:17:44 from (66.146.249.116):
In Reply to: No Oil Pressure on rebuild posted by Thomas D Windsor on June 18, 2007 at 20:09:33:
If you did something wrong, it wasn't the Vaseline. Filling the pump with Vaseline is fine, the pump is effectivly primed before you start it. If you remove the pump to clean out the Vaseline you will be boxing a dead clown, once the pump has turned it has pumped the Vaseline into the system and pulled oil up behind it. The pump can't just wipe the grease out of the way and plug the passages and stop, it pumps it. I do the same thing with every pump I have open, have even used gun grease if it is hot out. Having said all that, pressure pre-lube is the best, as you can watch and see that oil is reaching all the places it should before the engine starts.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
