Re: No Oil Pressure on rebuild
Posted by souNdguy on June 19, 2007 at 10:27:02 from (12.64.30.172):
In Reply to: Re: No Oil Pressure on rebuild posted by Patrick Martin on June 18, 2007 at 21:53:04:
I'm with Bob... so what type of impellor type gear pump are you talking about? A water pump ont he front of the engine is an impellor pump... the oil pump will be gear type and positive displacement.. the vasolen has no where to go but out.. and when it goes out... if there is oil at the pickup tube.. it's going up. I can't imagine an impellor type oil pump that would set above the oil resevoir with a pickup tube...
What other fantasy physics theories you got?
Soundguy
