Re: No Oil Pressure on rebuild
Posted by Gary in Mozarks on June 19, 2007 at 10:35:51 from (66.43.47.67):
In Reply to: No Oil Pressure on rebuild posted by Thomas D Windsor on June 18, 2007 at 20:09:33:
Probably some guys on here will think I am nuts but, Old ford flathead V8's had a hard time picking up oil after a rebuild, and An old timer I knew used to fill the dang crankcase plum full of oil so the pump was sumerged for the first start. As soon as it started he would take half the oil back out. I do not know if that trick would work in your case but at least you know about the concept now.
