Re: Ballast resistor question
Posted by El Toro on June 19, 2007 at 14:51:56 from (205.188.116.73):
In Reply to: Ballast resistor question posted by Rags on June 19, 2007 at 08:17:06:
You install the ballast resistor between the ignition switch and the coil. Hal
