Re: Belly pump-liftall
Posted by Dan-Illinois on June 19, 2007 at 16:51:48 from (12.147.63.126):
In Reply to: Belly pump-liftall posted by Dan - illinois on June 14, 2007 at 13:40:19:
Thak you for your suggestions. I believe my next step will be to take the suggestion on the hydraulic cylinder. The cylinder has a flow reducing orifice and maybe when the oil is hotter it is restricting the flow enough not to work properly. With that change it may work similar to adding the bigger cylinder as suggested.
