Re: Ballast resistor question
Posted by DelMN on June 19, 2007 at 17:50:05 from (70.100.37.186):
In Reply to: Ballast resistor question posted by Rags on June 19, 2007 at 08:17:06:
If you have a 12 volt coil, the resistor should be between the coil and distributor. If you have a 6 volt coil, then between the ignition switch and coil.
