Re: IH 254 Hydraulic Stopped Working
Posted by Allan In NE on June 19, 2007 at 18:09:51 from (148.78.243.25):
In Reply to: IH 254 Hydraulic Stopped Working posted by Shredder on June 19, 2007 at 17:28:41:
Norm,
Just looking thru the IT manual here.
That hydraulic filter appears to be a full-flow filter. That is, all oil must pass thru the filter before it can even get to the pump up in front of the radiator. Is it good? Is the pump mechanically connected?
Did you get in the full 3 1/2 gallons of oil? I put 5 in mine just to be sure.
Allan
