Re: Bob Melvin Diagram problem
Posted by John T on June 19, 2007 at 18:39:18 from (66.244.83.147):
In Reply to: Bob Melvin Diagram problem posted by Dirkey on June 19, 2007 at 18:07:33:
Typical values of Ignition Ballast resistors are around 1.25 to 1.85 ohms. Ive seen them smoke the first time wired cuz theres residue n maybe some film to burn off as they do run pretty darn warm. If possible heat sink them via their metal mounting clip bonded well to a big hunk of iron. I take it youre talking about the in line series ignition ballast between the ignition switch and a 6 volt coil on a 12 volt tractor, correct???????? cuz they do run hot...... Many (so caled bathtub style) are white and around 1/2 x 1/2 x 3 inches and look like a wirewound resistior encased in a ceramic/porcelain bathtub enclosure. If all is wired correct and were talkin of an ignition ballast resistor there shouldnt be smoke when you hook up the battery BUT ONLY if you turn on the ignition switch SURE YOU GOT THE RIGHT RESISTOR IN THE RIGHT PLACE When I wire a GM 10 SI 3 wire alternator rigged to work like a one wire I use a 10 ohm current limiting resistor in the excitation circuit BUT THATS NOT THE SAME AS THE IGNITIION BALLAST SURE YOU WIRED THE BATERY NEGATIVE GROUND!!!!!!!!! if not you can fry the alternator. STILL IT SHOULDNT SMOKE BY HOOKING UP THE BATTERY if wired right theres no current in it until ignition is on BETTER RE CHECK YOUR WIRING AND FOR NEG GROUND John T
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
