Re: Bob Melvin Diagram problem
Posted by Bob M on June 19, 2007 at 19:41:03 from (69.205.124.61):
In Reply to: Re: Bob Melvin Diagram problem posted by Dirky on June 19, 2007 at 19:08:07:
It's perfectly normal for a ballast resistor to smoke the first time it's powered up. (The internal resistance element gets hot enough to burn off any oil, etc. left over from the manufacturing process the first time it heats up). Also the resistor's ceramic housing will likely get too hot to touch after the engine has run a few minutes. This too is normal.
So a smoking resistor the first time the tractor is run is not really a concern.
However if the resistor smokes when you connect the battery and the ignition switch is OFF, you've definitely got a wiring problem!
