Farmall Tractors Discussion Board
Re: Re: Re: Re: My M won't move!
Posted by karl fischer on May 13, 1999 at 14:07:36:
In Reply to: Re: Re: Re: My M won't move! posted by The Red on May 13, 1999 at 12:56:40:
my H had a similar problem...the bottom of the shift lever wears out too much to contact the sliders, and jumps over them. you can see the sliders...you move them all so the channels line up. i used a wrench to slide them into neutral.
different shifter solved the problem.
Post a Followup
: Re: Re: Re: Re: Re: My M won't move!
