Re: Power Take off on Cub What to do next
Posted by Roger46 on June 20, 2007 at 19:38:11 from (69.58.159.18):
In Reply to: Power Take off on Cub What to do next posted by Farmall Ed on June 20, 2007 at 13:49:48:
There are several things to cause the PTO of a Cub to slip out. It could be the ball detent, worn shifter, bad bearing, bad splines (what I had on mine and ended up replacing the transmission shaft). You need to take it out and see which of these things is the major cause. Roger
