Re: Farmall H brakes?
Posted by randy hall on June 21, 2007 at 05:23:23 from (209.11.236.48):
In Reply to: Farmall H brakes? posted by Aaron B on June 20, 2007 at 22:23:52:
that screw is to keep the brake band from rubbing on the top of the brake drum all the time. you screw it in tight then back it out a turn and lock the nut.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
