Re: Brakes Farmall H
Posted by Andy Motteberg on June 21, 2007 at 13:55:45 from (65.54.98.29):
In Reply to: Brakes Farmall H posted by Alan Martinson on June 21, 2007 at 13:44:18:
you need to pull out the pins. Don't use any oil or lube in the brakes.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
