Re: Brakes Farmall H
Posted by Ronald on June 21, 2007 at 19:29:58 from (152.163.100.197):
In Reply to: Brakes Farmall H posted by Alan Martinson on June 21, 2007 at 13:44:18:
If I understand you right you have the band and cover off the tractor, and the arm that clamps on the shaft off, but the woodruff key won't come off to get the shaft out of the cover? Take a small chisel and tap on either end of the key and it should kinda roll out of the shaft. After the key comes out the shaft will come out of the cover and you can tap the pins out of the bands and replace band.
Ronald
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
