Farmall Tractors Discussion Board |
Re: Hydraulics on M Farmall
Posted by Jim on May 17, 1999 at 07:27:19:
In Reply to: Hydraulics on M Farmall posted by Matt Steele on May 16, 1999 at 18:55:01:
Do you happen to be returning oil into the filler pipe or below it with a T fitting.If you are some times it will blow oil all over.And the anser to your question is yes there is a drilled hole in the cap.
Post a Followup
