Farmall Tractors Discussion Board
Re: proper way to measure Farmall 100 or A oil level
Posted by big fred on May 18, 1999 at 07:06:39:
In Reply to: proper way to measure Farmall 100 or A oil level posted by RIck K on May 18, 1999 at 06:22:01:
I've always checked mine cold, before I start it. Figure that's the sensible way, as you aren't that interested in oil level after you shut it down. As far as the filter draining, I can't say what is right, but the operators manual says to drain the oil filter before taking the housing off to change it, so I would guess it normally should have oil in the filter, and it should not drain back to the oil pan.
Post a Followup
: Re: Re: proper way to measure Farmall 100 or A oil level
