Farmall Tractors Discussion Board
Re: farmall 450 gas won't start
Posted by pete on May 19, 1999 at 19:24:09:
In Reply to: farmall 450 gas won't start posted by mark s. on May 19, 1999 at 19:04:35:
remove number 1 spark plug put finger in plug hole and crank slow when you fell compresion turn till the marks line up on front pulley.then check where the roter is this no 1put the wires in order starting with no 1. it will run. good luck.
Post a Followup
: Re: Re: farmall 450 gas won't start
