Farmall Tractors Discussion Board
Re: 806 PTO will not engage
Posted by Greg on May 20, 1999 at 15:48:11 from (152.163.232.18):
In Reply to: 806 PTO will not engage posted by david on May 20, 1999 at 07:13:14:
On the 806's I had it was usually the pin....suprisingly enuf it's so small u should take an envelope w/ you to the parts Dept so u don't lose it....About a 20 min job after you've done it once....I'd see if someone will show you how, then next time you'll be set....Good Luck !
Post a Followup
: Re: Re: 806 PTO will not engage
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
