Farmall Tractors Discussion Board
Re: Re: Re: Re: Another charging followup. Found the culprit
Posted by The Red. That is what Mrs. Red Says. on May 23, 1999 at 03:06:13 from (216.192.172.36):
In Reply to: Re: Re: Re: Another charging followup. Found the culprit posted by RKS - you have a problem on May 22, 1999 at 12:36:50:
I have H-itis. RKS I will put my 1 amp trickle charger on there and let it soak up for 2 or 3 days. The battery has not had a generator on it for 3 months. Even though I was using the trickle, I suspect the battery is well down. Hard to tell because it can be almost dead and the 6 volt starter still turns quickly. I have had that happen before.
I will also get a load test on the battery. The voltage regulator is a brand new Delco Remy so I think its fine.
I will keep you informed. SLOWLY but surely, this H is gonna get straightened out!
Post a Followup
: Re: Re: Re: Re: Re: Another charging followup. Found the culprit
